Insturment cluster dies when lights turn on.
Old Apr 27, 2011 | 10:22 AM
FletchMasta's Avatar
Hey guys, I just converted my 92 RS 305 TBI to a 350 carb and everything works except when I turn my headlight switch to park or on the cluster dies even when the engine is runngin. Not just the lights on the gages but even the signal it gets from wherever. All the needles drop to zero as if the car was off, but everything else is still working normally. When I turn the head lights back off they work again. Any help would be awesome. BTW I just bought a GM Service Manual (the really thick books repair shops use) so hopefully that will help me a lot because the wire diagrams in the Chiltons and Haynes manuals don't go into enough detail.
Old Apr 27, 2011 | 12:35 PM
Re: Insturment cluster dies when lights turn on.
Also on the wire diagram when it says "RH Turn Indicator" does RH= Driver side or what? Just need clarification on that because in my mind it does.
Old Apr 29, 2011 | 10:31 AM
Well so far I found that pin 2 on connector C2 behind the gauge cluster is not getting ground like it's supposed to, instead its getting 8VDC. So now I've got some digging to do!
Old May 12, 2011 | 11:12 AM
Figured it out. One of the ground wires to the cluster was cut for some reason. Regrounded the wire and everything works perfectly. That GM SDervice Manual really helped!!! I would recommend everyone who is having wiring issues to buy it!
Old May 12, 2011 | 11:13 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Originally Posted by FletchMasta
Figured it out. One of the ground wires was cut for some reason. Regrounded the wire and everything works perfectly. That GM SDervice Manual really helped!!! I would recommend everyone who is having wiring issues to buy it!
Gonna guess it was the one under the steering wheel coming out of the main loom there. Mine was missing that one too.
Fronzizzle
Aug 17, 2015 02:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
