battery drain. possible headlight related
Old Apr 29, 2011 | 06:53 PM
FxsX24's Avatar
Car: 1994 s10
Engine: 283
Axle/Gears: 4.10, one spinner
so my dads 88 t/a has a draw somewhere. he did the test light method and pulled all the fuses and relays he could find. it still light the light up.
today we noticed a issue when hooking the positive back up. when you touch the wire to the battery , the headlights will click (or retract if they are up} and the chime will chime once (sometimes). this is with all fuses hooked back up.
is this normal?
also we had the negative cable unhooked for a few days, and the battery was dead when we hooked it back up. battery was fine in plow truck all winter,
Old May 1, 2011 | 06:24 PM
FxsX24's Avatar
Car: 1994 s10
Engine: 283
Re: battery drain. possible headlight related
upon further investigation we found that the center console door is warped and did not shut the light off.
MM2Robinson
Oct 1, 2017 09:16 AM
Grant2k
Apr 4, 2016 08:21 AM
apie2546
Sep 24, 2015 12:27 AM
Isaac McCormick
Sep 12, 2015 10:20 PM
andy74
Sep 3, 2015 08:41 AM
