Blinker Doesn't Work When Brake Is Pressed, or When Headlights Are Turned On
Old May 4, 2011 | 10:13 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
The passenger's side blinker works fine when the brake pedal isn't pressed and headlights aren't on. But as soon as lights/brake are engaged, the blinker doesn't work, and the dash indicator just stays lit up constantly; doesn't blink.
Anyone have any ideas on what might be causing this?
Thanks.
EDIT: Problem solved, replaced the bulb with the wrong one
Old May 5, 2011 | 07:23 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: Blinker Doesn't Work When Brake Is Pressed, or When Headlights Are Turned On
Anybody?
I know it's not the most exciting subject in the world, but I'm kind of at a loss here.
I changed the bulb, but don't really know what else to do.
Old May 9, 2011 | 10:45 PM
Bronk's Avatar
Car: 82 Camaro Z28
Transmission: auto
common on chevys ...replace the signal light bulbs Usaualy in the front, what happens is the bulb filament shorts to the other circuit.
Old May 11, 2011 | 03:13 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Thank you for the reply.
I've already changed the bulbs, but still the problem persists. I'm a bit stumped. Any other ideas?
Old May 13, 2011 | 03:35 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Poor ground connection in one of the light sockets. Look at the little ground tab that makes contact with the base of the bulb. They will break causing the ground circuit to become open. This leaves the filaments grounding through each other and fouls the operation. You'll know this is happening by turning on the lights and flashers alternately and seeing if the wrong filament lights up on one of the bulbs. Since it's affected by the brake lights, I would expect it's in one of the rear sockets.
Frozer!!!
Jan 19, 2024 04:55 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Wade787b
Sep 29, 2015 01:15 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
