Turn signal issues
Old Nov 9, 2010 | 11:06 AM
Brian87iroc's Avatar
Car: 1987 IROC Z28 Camaro
Engine: 350TPI
Turn signal issues
New to the board.
I recently purchased a 1987 Iroc Camaro. After purchasing it I did some checking and found that the front right turn signal was burned out. It was causing the right arrow light inside the car to come on every time I hit the brakes. So I went to Walmart, purchase a 2057A bulb and went home and put it in. Checked it and it worked fine. Later that night, I went to take the car for a spin, and when I clicked the headlights on, the right turn signal light comes on and stays on. I got out of the car and looked around and my right rear turn signal light is on and stays on, and it appears the front is doing the same. It won't flash when I turn the turn signal on.
It only does this when the headlights are on. When they are off, both turn signals light up and function normally. I've tried another 2057A and it does the same thing. Now the bulb socket has some corrosion inside there. Could that be causing it? Where do I begin my trouble shooting process?
Hopefully you guys can point me in the right direction. I've searched the forums but nothing I found was my problem exactly. Thanks in advance.
Brian
Old Nov 9, 2010 | 03:15 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Turn signal issues
You might try cleaning the socket of corrosion and checking the turn sig wiring for any sign of the insulation being broken or nicked that might cause a short to ground. Sounds like your getting battery but the turn sig relay isnt able to complete the flash cycle for that particular lamp.
Old Nov 10, 2010 | 06:55 AM
Engine: 350TPI
Alright, my brother in law tore into the car last night. Its had some electrical "rework" done to it. Now gotta find electrical schematics and redo the wiring.
Can someone tell me, are the sidemarker lights supposed to flash with the turn signals?
Old Nov 10, 2010 | 11:14 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Mine do, not sure if that is the case for all years though.
Old Nov 10, 2010 | 11:40 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Brian, check your rear tail/brake bulbs. I've seen the wrong bulbs and even the right bulbs installed wrong. The reason I say that is when you hit your brakes your indicator comes on in dash. That's a sign that the problem is in the rear. No brake lights on front.
Old Nov 12, 2010 | 06:59 AM
Engine: 350TPI
Yep, the wrong bulb was installed in the rear. Some on installed a 1156 in the rear instead of the 2057 that it calls for. They had rewired the rear turn signal to the front sidemarker light because the factory wiring had died. I guess the problem must be in the turn signal switch or a break in the wiring somewhere along the way. I was forced to wire it back up the way they had it til i can trace the issue.
Thanks for all your help. I guess the next step is to find out where the turn signal switch is (steering column perhaps) and see if there is power coming out of it. If so I've got a broken wire to the rear.
Old Nov 12, 2010 | 09:49 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You have to pull the steering wheel off to get to it. You'll need the tool to take off the lock plate as well.
Old May 13, 2011 | 04:52 PM
Engine: 350TPI
I finally got the car back out and took it apart. I was trouble shooting the rear signal and I guess it had a loose connection under the dash because when I reassembled it, it worked perfectly. So glad to have that out of the way. Was really worried about it. Also the brake light on that side had the wrong bulb in it as well, and was causing ALL kinds of crap. Its amazing what such little things can do. thanks for the help.
Old May 13, 2011 | 07:56 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
For the future - here's wiring diags if you need: http://www.austinthirdgen.org/index.php?pid=19
There's a ton of 1992 stuff, but alot of the 'basics' will be the same between the years (like lights, cruise, hatch, etc.).
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
