Headlight issue... Any expertise appreciated
Old May 13, 2011 | 10:17 AM
tstak's Avatar
Car: 1991 Pontiac GTA Trans Am
Engine: 5.7L
Axle/Gears: 3:23
Sorry to post something that may have been covered. Car is '91. Already replaced bad RH motor. Both motors work fine plugged into driver side. Removed and opened control module off firewall. Circuit board, relay look flawless w/ no indication of damage. When I was removing bad motor, I forgot to unplug it first. I thought I heard a shock when my wrench made contact w/ some of the many obstructions around lamp motor? Thought I was hearing **** until now. Did I blow part of module that controls right side motor? What about the fusible links? Found this diagram in a previous thread. Which would be RH fusible link?
Note - Gear box cover came loose on passenger lamp motor causing gear to get chewed up. Everything worked fine until I heard that shock. No power to right side plug
Attached Thumbnails Headlight issue... Any expertise appreciated-fusible-links.gif
Jonesyfxr
Sep 26, 2015 02:08 AM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
luvofjah
Sep 3, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
