Z28/iroc 86 Tachometer & other issues
Old May 14, 2011 | 02:09 AM
PeteyPabs's Avatar
Car: 86 Iroc with z28 body
Engine: modded 305
Hows it going guys? im new here and new to working on these beasts, i got myself a Camaro where the guy whom i got it from had the motor rebuilt several times and now its just a carbed 4 barrel 305 with edelbrock intake,electric fan, hooker headers, edelbrock filter yadayada. BUT a good amount of my fuses are gone and a whole bunch of wires under the hood are unplugged/cut, all my lights work and the engine runs fine (with the exception of the third rear tail light for some reason) what doesn't work however is the Tach, the interior blinking lights for the blinkers and the interior dome light... looking for someone to help me out show me a diagram or tell me some steps to do, mainly im just trying to get the tach back hooked up but it would be cool to have it all working again.
p.s. anyone have any idea why when i open the drivers door the floor lights come on but not when i open the passenger door?? Thanks in advance!
Old May 14, 2011 | 06:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Z28/iroc 86 Tachometer & other issues
Welcome to TGO.
Wiring diagrams may be helpful:
http://www.austinthirdgen.org/index.php?pid=19
JamesC
Old May 15, 2011 | 08:18 PM
PeteyPabs's Avatar
Engine: modded 305
thanks for that james, i kind of got a vague idea with those diagrams.. i got the interior dome light working by just putting the bulb back in there
Old May 15, 2011 | 08:22 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
does your exterior blinkers work though? if so more then likely have a burnt bulbs, happened in mine. or a fuse could be blown, but id suspect all the dash lights would be out, there a simple fix
Old May 16, 2011 | 11:17 AM
PeteyPabs's Avatar
Engine: modded 305
yes front and rear blinkers work, headlights hi and low work too. only thing i cant really figure out is the third brake light, the bulbs look fine and i dont have a voltage meter to test the terminals right now, anybody know if there is a seprate inline fuse or seperate fuse on the panel for it?
and i still cant figure out why the interior dash blinker flashers dont turn on when the blinkers go on, just the beeper.. thanks guys!
Old May 16, 2011 | 11:18 PM
PeteyPabs's Avatar
Engine: modded 305
i think i may have found the green tach wire coming off the distributor, only problem is it looks cut about 4 inches from the distributor, i noticed another green with with some kind of strange looking connector on it hanging loose on the right side of the engine bay, im hoping aslong as i connect this the tach will work again... thoughts? sound good? haha
MM2Robinson
Oct 1, 2017 09:16 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
