Headlight motor cheap easy fix.
Old May 19, 2011 | 05:50 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I just had to fix one of my head light motors. The headlight could be pulled up and down so I suspected the gear wheel. However, when I opened it up, I found the nylon gear wheel looking perfectly normal. What was broken, literally in tiny pieces, were the bushings that sit inside the wheel and stop the metal shaft from turning relative to the wheel. You can get a kit that contains the circular bushes but you get other stuff that I didn't need and didn't want to spend the money. So, I got a piece of 1/2 inch wooden dowel, cut 3 7/16th length pieces and chamferred the ends. These fit perfectly in the circular spaces formed between the nylon gear and metal shaft. I can't think of anything wrong with this almost zero cost repair. Anyone else?
PS sorry TDS.
Old May 19, 2011 | 06:01 PM
collin2201's Avatar
Car: 91 GTA / 68 Mustang Coupe
Engine: LB9 305 / 302
Re: Headlight motor cheap easy fix.
I've known people to cut up hot glue sticks for bushings as cheap fixes as well. Nothing too revolutionary.
Old May 20, 2011 | 10:51 PM
blackformula350's Avatar
Car: 1990 Trans Am
Engine: 5.7 TPI with goodies
Transmission: Autotragic
I have always used 1/4 rubber hose, not soft hose either.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
mhatfield 14
Aug 15, 2015 10:47 AM
stalkier
Aug 13, 2015 12:59 PM
