CAMARO glovebox light?
Old May 20, 2011 | 09:02 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Has anybody put a light in their camaro glovebox? I am thinking of doing it just for a little extra thing, but I need ideas on hwo to have it switched on and off. And how would I wire it? Where would teh power source come from?
Old May 20, 2011 | 10:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: CAMARO glovebox light?
In the center console, or in the lock box in the driver rear?
Old May 20, 2011 | 10:29 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
My 'bird console has a light in it. If the Camaros didn't get the light, I bet you could always pull one out of a 'bird console & fit it into your Camaro console.
Old May 21, 2011 | 07:46 AM
chevydrvr's Avatar
I was talkign about thec enter console. If I remember right, there is already a hole there which looks like a light would go there.
Old May 21, 2011 | 08:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The hole is for the clock stem (some cars were equipped with an analogue clock). You might consider LED's in the dome light. I swapped a board into my overhead console and the difference is remarkable.
JamesC
Old May 21, 2011 | 09:11 AM
Car: GTA
The analog clocks were on top of the console. He is referring to a hole inside the center console "glove box".
Which is where I'm sure he is saying his hole is. Inside the compartment on the front wall, just like mine is.
I think the socket for the bulb clips to the back of the lens just like the rear compartment/"trunk" light does, under the hatch right by the pulldown motor/latch assembly.
Old May 21, 2011 | 09:26 AM
JamesC's Avatar
As I mention above, the hole (inside the compartment) is made for the stem on the Camaro analogue clock.
EDIT: Since I've never seen pics of the stem on site, here are a couple.
JamesC
Attached Thumbnails CAMARO glovebox light?-img_0192.jpg   CAMARO glovebox light?-img_0193.jpg
Old May 21, 2011 | 09:41 AM
chevydrvr's Avatar
How would I have it switched on and off? I'm not doing to because it's too dark in there, I just want a little in my interior.
Old May 21, 2011 | 11:32 AM
Car: GTA
Here is the Firebird one. Bigger the just the tiny hole & the pressure button on top that turns on the light when you open the console cover, just like the doors press on a switch to turn on/off the overhead interior light.
I don't think the Camaro lids cover the top of the console as much as the Firebird covers do, but I bet something could be figured out for the pressure switch.
Worst case? Use a hatch light that has the switch built in. Just won't turn on/off the light by itself for you.
Either way. Have to cut a hole rather than just drilling a hole like that clock shaft.
Attached Thumbnails CAMARO glovebox light?-p5210011.jpg   CAMARO glovebox light?-p5210012.jpg
Vintageracer
Jan 10, 2020 05:33 PM
TheJoeY88
Dec 31, 2016 07:30 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
