autozone halogen fog lights ok to use in stock wiring?
Old May 28, 2011 | 09:17 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Wondering if its safe to have these halogens in our stock wiring??? there identical to our stock fogs but use a halogen bulb instead. thanks for the feedback
Old May 28, 2011 | 10:28 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: autozone halogen fog lights ok to use in stock wiring?
What is the wattage rating on the bulbs? Take that number and divide it by 13. Then multiply by the number of bulbs(I'm guessing 2). As long as the number you get is below the rating of the stock foglight fuse then you will be fine.
Honestly, if they are 55 watt bulbs which is pretty standard, then you should have no problems.
Old May 29, 2011 | 12:43 PM
maks10's Avatar
Car: 1990 Trans Am
thanks for advice almost positive its 55w bulbs but i figure to check
jaridjohn
Jul 8, 2024 03:49 PM
Jeremys87
Jul 14, 2022 09:08 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
