Where is the starter enable relay?
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
Can't tell from the Hayne's Manual. I need to check this before I determine what the problem can be, afraid it is a VATS issue, but one step at a time...
Thanks!
Thanks!
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Where is the starter enable relay?
It's behind the driver side kick panel and covered with a strip of that sound deadening tar-like stuff. It's almost at floor level.
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
my vats is screwing up in my car, the key'd value is 523 for mine, and its not grounding the fuel pump & INJECTORS. So I'm getting mad, lol
Gunner242
Dec 25, 2015 04:49 PM
