battery keeps dying ..i need suggestions
Old Jun 13, 2011 | 02:35 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
well my battery keeps on dying and i keep recharging it. at first i thought it was just a bad battery but i didnt have funds to buy a new one and kept charging the battery overnight. when i got the money i purchased a new duralast gold from autozone and it worked fine until today in the morning. usually it took a fully charged battery two days to discharge on this car. so i wanna know where i should start looking to see where im getting drained from.
i recently did the led swap to all my internal lights dash, overhead, shifter, hvac controls, and trunk. could this be a problem? also i have no radio but my fuse was still plugged in. all the fuses are intact but kinda old, like they look foggy on the terminals. should i replace them all with new fuses?
lemme know what you guys think i should do to keep my birdy alive
- Aaron
Old Jun 13, 2011 | 03:33 PM
BillyTheGoat's Avatar
Car: 1989 Trans am
Re: battery keeps dying ..i need suggestions
It seems like the alternator. grab a volt meter and check the voltage of the battery by itself and then check the voltage with the car running, It should have over 13v.
Old Jun 13, 2011 | 06:24 PM
Mailman818's Avatar
Engine: 2.8L V6
yea it runs like at 14 volts while running and sitting its like a lil over 12 volts. my alternators not bad since its brand new. i found one bad fuse possibly it was that?
i checked my two spots in the fuse spot and the secret fuse spot to the right of the other.
could it have been that one fuse?
is there another place i should be checking for fuses or is it those only two spots?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
L0tuS
Sep 4, 2015 11:16 PM
