INST LPS Fuse keeps popping
Old Jun 14, 2011 | 12:13 AM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
is there anything obvious to check because i have yet to figure this problem out. My dash lights will come on for about 1/2 second then pop the fuse.
Old Jun 14, 2011 | 01:07 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: INST LPS Fuse keeps popping
Electrical shorts are usually caused by a small section of wire insulation that has been scraped bare and is in contact with a ground on the car. You will have to check all the wiring under the dash to find the culprit location. If you can isolate setions of the wire by disconnecting connectors, measure the ohms reading from end to ground. If you get a 0 ohm reading that is the section where the short is. Also make sure you remove the instrument cluster and inspect it closely, and check the connectors that the instrument cluster plug into.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
thunder57
Nov 7, 2015 02:28 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
