194 Bulb WITHOUT Socket? #?
Old Jun 26, 2011 | 07:11 PM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Does anyone here know the part number for the SOCKET itself?? I contacted 2 local GM Dealers and they could not even find out themselves and they are GM DEALERS??
It appears # 25089350 is the BULB AND Socket (1 piece soldered).
The problem is that they sent my cluster to Calgary to fix it and I had ordered $80 (after stupid taxes, duty, and shipping/handling) on LED's for the instrument cluster. I discover the company who they sent the cluster to has replaced with all 1 PIECE bulb/sockets and now these LED's are completely USELESS and I'm out $80!
After contacting the dealer they said nothing can be done and "york electronics" in Calgary won't ship my originals back.
So now I have no choice but to look for them on eBay!
Old Jun 27, 2011 | 02:46 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: 194 Bulb WITHOUT Socket? #?
Try Standard Motor Products part# S503A. The first digit is the letter "S", the second is the number five.
Type the part # into this website:
http://www.standardbrand.com/Online%...g/Content.aspx
Old Jun 27, 2011 | 02:54 AM
Only thing is that the S503A seems to be for a 1967 - 1987 Camaro online according to the compatible years listed.
Old Jul 1, 2011 | 11:35 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
could you send a photo of the sockets you have? quite often they can be reused with normal bulbs, the ones in there are just need to have their leads unsoldered from the bottom of the socket. I know I have bought these from my local advance auto before under the motormite/dorman/help brand, but no part number to give unfortunately.
Old Jul 1, 2011 | 12:00 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
91 92 cannot remove bulbs from sockets,u cant just unsolder, as the base is different. and there not really soldered more like tack welded,solder wont stick,been there done that. get bulb sockets from an older car.all gm use the same sockets for the most part.
Old Jul 1, 2011 | 09:41 PM
Can't with these. There is a wire that is tack welled to each outside contact from the bulb. There is also little prongs inside that take up all the space. There are also no metal prongs inside where it would normally touch the prongs on the bulbs.
Old Jul 1, 2011 | 10:31 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Do you need just sockets so you can install #194 wedge base LED replacements? I have a small assortment of some that I "borrowed" from the junkyard on certain visits. IIRC, the 90-92 cluster requires four lights to illuminate the gauges and a few more to illuminate indicators. I'm sure I could spare a few.
Old Jul 4, 2011 | 02:58 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Something I just thought about!!
Try rotating the sockets 180*??
I hear some sockets have to be put in a certain way to get power.
Maybe it's just LEDs, IDK, worth a try???
& I owe you a nickel change..
Old Jul 4, 2011 | 04:03 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
What sockets are you needing? Pic? Only instrument 194s I've seen use separate sockets, not a combined bulb+socket in one.
Old Jul 4, 2011 | 05:42 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I've got lots of extras of those from 90-92 clusters. Get in touch
Old Jul 4, 2011 | 06:16 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
http://www.happcontrols.com/lighting/49094100.htm
48¢ each + shipping if you want new ones. They also sell packs of 194's or 359's if you want something brighter.. be careful with the 359's though, they get hot.
Old Apr 6, 2012 | 04:34 PM
kitt23's Avatar
Anyone have any for a 82-84 trans am?
Fronzizzle
Feb 9, 2017 09:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
ramicio
Sep 28, 2015 01:18 PM
roysatikas
Sep 22, 2015 08:15 PM
