Problem with horn
Car: '92 Camaro RS
Engine: 305 tbi
Problem with horn
I'm working on my first Camaro, 1992 RS 305tbi, and I've found that the horn doesn't work. When I press on the steering wheel, where the horn buttons should be, I hear no noise coming from the relay, causing me to think the problem is in the fuse or the relay. I want to make sure the horn buttons are acting normally before going out and spending money on a new relay. When pressing on the wheel, should I feel an indication that the button is being depressed? On my other cars (not Camaros), I feel a slight click when the horn is pressed. My second question; in the fuse box, what is the horn's fuse labeled as. I checked all the fuses already, but I want to double check that one in particular.
Thank you, any help is appreciated.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
He’s A Soft Touch
You won’t feel a *click* from the horn buttons, they’re Sof-Touch buttons.
To find out if they’re good remove the knee bolster.
The relay is to the right of the steering column.
Use a voltmeter to probe pin J on the relay.
When you press a horn button the voltage will go to zero if the button is working.
Happy Racing!
Don’t Ask Me Why I Don’t Get Dizzy After Going In 400 Circles
Happy Racing!
Car: '92 Camaro RS
Engine: 305 tbi
Re: Problem with horn
Hey, reviving an old thread.
I finally got around to taking another look at my horn. I replaced the relay a while back, but that didn't fix the problem so I took the steering wheel apart and found this.
One of the buttons is missing and the other is just flopping around. Is there supposed to be a spring or piece of metal that keeps the buttons from being depressed all the time?
Also, should there be a current coming from the red wire?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
red wire should have a constant 12v. when you press the horn buttons it grounds the circuit and sets off the horn. sounds like both horn buttons are broke
Car: '92 Camaro RS
Engine: 305 tbi
Yeah, both are broken and there's no current running through the red.
Guess I'll have to pull apart the rest of the column
