electrical problem
Old Jul 13, 2011 | 10:24 PM
redtransam85's Avatar
electrical problem
i was replacing my starter and it had slipped my mind to unhook the battery. but i sparked the soleniod and the frame and now i have no buzz when i turn the key no lights outside or insida at all. car wont start but starter will spin i believ it has power because i have a push button start on the car. what do i do. please help
Old Jul 14, 2011 | 09:41 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: electrical problem
it sounds like you may have blown one or more of the fusible links, as they're right at the starter and lead to the interior fuse box. i would start by checking those to see if they popped and need to be replaced. also check all of your interior fuses, probably lost a few of those too
Old Jul 14, 2011 | 03:22 PM
well my car has a push button in it and the starter is the only thing i can get power out of
Old Jul 14, 2011 | 03:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Exactly, so check the fusible links.
Old Jul 14, 2011 | 03:58 PM
where are these at? im new to the whole electrical deal and ive had this car for about a week. any insight to the most problematical one?
Old Jul 18, 2011 | 04:09 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
You Have No Buzz? Open More Champagne
As indicated in a previous post, look near the starter.
But you need to know what you’re looking at.
Fusible links merely look like a piece of wire which was spliced in, sometimes encased in plastic.
They are usually
rust in color.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the nearest junction point to determine which one(s) you will need to replace.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
