Hayden 3651 Fan Control Relay Clicking
Old Jul 19, 2011 | 08:37 PM
scotty64's Avatar
Just installed the above on a '92 305 TPI. Everything is working as it should (turning on AC turns on fans, fans come on at about 180 degrees, adjusting screw on controller varies the on/off temperature point).
But, the relay clicks like crazy just before the fans come on or just after the fans shut off. I confirmed this by turning the adjusting screw--it I turn it so the fans come on--clicks stop. If I turn it so it would take a lot more temperature to turn the fans on--clicks stop.
I assume it isn't the relay itself because everything works as it should otherwise. Bad ground? Bad controller? Something else?
Old Feb 19, 2012 | 10:50 PM
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
Re: Hayden 3651 Fan Control Relay Clicking
I have the same exact issue, did you ever correct this?
my86bird
Oct 23, 2015 12:20 PM
64goatman
Sep 9, 2015 01:09 PM
IROCZ1989
Sep 4, 2015 11:54 AM
85Special
Sep 3, 2015 04:21 PM
