Big three question?
Old Jul 22, 2011 | 06:43 PM
91rscammie's Avatar
Car: 91rs,00outback,02f150screw rip wrx
Engine: lo3, 2.5,330ci
Big three question?
I am doing the big three and I was just wondering what the consensus was. To star washer the grounds or not to. While taking the original battery to engine ground off I notice that there's a star washer between the ground wire and block. So I cleaned up the block to get ready to attach the larger ground wire. Then I started fighting with myself to install that star washer or not. Plus when connecting to chasis clean and star washer or not ?
Also I will have the two factory locations battery neg. to chasis, and battery neg. to engine ground, Plus that same engine ground to the same chasis ground. Can I also ground the alternator to the chasis on the other side or will this cause ground looping, and noise?
Old Jul 23, 2011 | 08:00 AM
91rscammie's Avatar
Re: Big three question?
Ok, nobody knows or should this be posted in car audio?
Old Jul 23, 2011 | 09:40 AM
mrrman's Avatar
I used star washers on all my grounds but also scraped the paint off around the contact points.
Old Jul 23, 2011 | 05:36 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the alt doesnt have a ground wire, it grounds itself through its body to the brackets on the engine. if you connect a wire off the alt to ground youre gonna fry something.
Old Jul 23, 2011 | 05:54 PM
91rscammie's Avatar
Yes, I know this what I ment as many people do is attach a ground wire to a bolt that goes through the case. I have a cs144 and it has a place I can attach a wire to on back instead of the through bolt. Just wondering if with all the grounds I have now, if I add this (as lots off people do, just most don't have the other grounds too.) Will I get noise from ground looping in my audio?
Old Jul 23, 2011 | 10:00 PM
travis401's Avatar
Car: 91 Camaro RS
shouldnt get any noise from the added ground.
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
Leggman1
Aug 6, 2015 04:15 AM
