HITACHI Starter PSL100 install
Old Jul 31, 2011 | 04:29 PM
acc62001's Avatar
I am installing a PSL100 on my SB Chevy but have no idea what wires go where, Its a 65 Chevelle . i have a batt and 2 wires hanging but the new stsrter only has 3 leads.. one big and one small..does anyone have a schematic for this starter? I know this is for 3rd gen coms, but team chevelle has no threads.. thanks for understanding..
Old Jul 31, 2011 | 07:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: HITACHI Starter PSL100 install
PSL100 does not have the resistor wire (R) terminal commonly found on earlier Delco starter setups.
This wire ( usually red ) supplied 12V to the coil when cranking only to give a stronger spark.
Most coils were 9V? and had a ballast resistor to drop voltage down for running.
Your hookup will be heavy batt wire to big terminal on solenoid, starter wire (usually purple in GM cars) to the smaller solenoid terminal.
You may have other power wires ( to car ) coming off the big terminal as this was usual setup for power supply in earlier cars
Just thinking about it
you could hook the coil resistor wire to the solenoid terminal as that would only be hot when engine cranking but it may reduce voltage to the solenoid which is why GM had a seperate terminal that got power direct from batt when solenoid engaged
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
milk
Aug 10, 2015 06:26 PM
