Vats problem, Not resistor key
Old Aug 1, 2011 | 01:11 PM
dugan's Avatar
Working on a customers 86 camaro, with the 350.. supposedly a rare 86 camaro.. It has had many problems recently i fixed almost all except for the starting problem. I thought it was the starter but checked it and it was fine, next step was the vat system. I checked the key and it is not a resistor embedded key. The key will start the car once in awhile but other times it will lock up the PCM. I know how to bypass the Vat system, but i do not have a resistance value and the only way i found to get it was by asking chevy and they said "bring it in lets *** rape you for a 3 digit value" So is it possible to bypass the VATs relay with a jumper and use the stock key without a resistor?
Any info helps thanks
Old Aug 1, 2011 | 01:54 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Vats problem, Not resistor key
I dont think Camaro had Vats until 89?
GTA got it in 88
firbirds an camaros 89
No 86 camaros made with a 350 4 public until 87.
its a swap or 305(they look the same as a 350)..
I would start with checking the fuseable links down by the starter give them a continuity wiggle test.
I have had many of them fail inside of the connection from link 2 regular wire.
good luck
Old Aug 1, 2011 | 04:32 PM
dugan's Avatar
Didn't know about the vats. Just assumed. It will start sometimes now. But sometimes nothing. Solenoid is getting positive but wont turn car. If I arc it across with a screw driver fires right up. Maybe ignition is too weak of voltage I might convert into a button ignition with use of key.
Old Aug 1, 2011 | 05:03 PM
TTOP350's Avatar
is the purple wire getting 12 volts when you try 2 start it?
if not you may have a ign switch(down on the colum) or maybe even a neutral safety switch prob..
Old Aug 1, 2011 | 05:18 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
VATS was not in camaros/birds till 89, it was first intoduced in 86 only on the vette
Old Aug 1, 2011 | 06:05 PM
BillyTheGoat's Avatar
Car: 1989 Trans am
I jumped into the same conclusion when I first got my car and it turned out to be the after market alarm.
Old Aug 1, 2011 | 06:11 PM
TTOP350's Avatar
Wow I sooo forgot to ask about aftermarket alarm.. Thats normally the 1st thing I rip out of these cars.. 99% of them are juuuuunk!
It took me 8hrs to remove and fix the hack job alarm someone did to the last car i got that had starting problems. prolly one of those 100$ INSTALLED jobs that fail when you hit a bump!
Old Aug 2, 2011 | 04:50 PM
Car: 1989 Trans am
I still haven't taken off mine. I only removed the horns, it turns on whenever I open the door and randomly when I'm driving. It looks like they did a good job installing it since everything is behind the dash somewhere and they blended some wires pretty good. I need to take it off soon to put a proper alarm in there
Glowsock
Jul 24, 2025 03:15 PM
Street Lethal
Apr 30, 2019 12:14 PM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
Bryan F
Aug 18, 2015 02:28 PM
