87 Trans Am, completely dead??
Old Aug 2, 2011 | 06:34 AM
Flbandit98's Avatar
Car: 1987 Trans Am
Transmission: 7004R
I need help? Is there a master fuse somewhere? I started my car this morning and it stalled after running a few minutes so I went to restart it and it stalled again, this time everything went dead. Now I have no lights or anything? I checked the battery cables and tightened them. Still nothing when you turn the key. No idiot lights or anything. I am totally stumped??
Old Aug 2, 2011 | 06:53 AM
Re: 87 Trans Am, completely dead??
Likely, one of the fusible links down at the starter.
Old Aug 2, 2011 | 12:10 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
you have lost power from your battery. might be dead. tightening vcables may not fix the problem.other ideas: corrosion, burnt power wire, fusible links like sofa said.
Old Aug 3, 2011 | 11:12 AM
Flbandit98's Avatar
Car: 1987 Trans Am
Transmission: 7004R
Thanks guys for all your help. I found the problem to be a loose battery terminal at the starter. I tightened it and everything works fine now!!!
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
