HVAC Wiring mess... 89 Formula
Old Aug 4, 2011 | 10:01 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Trying to get this thing to work. The highspeed relay has no ground, no ground to the blower as well. Traced the wires back to other grounds tied in, in the hvac harness. Where does the grounds attach too? Inside the vehicle? has to...
Old Aug 5, 2011 | 09:25 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: HVAC Wiring mess... 89 Formula
Ground is actually in the engine harness. If you did a swap, you may need to check the wiring harness to make sure the ground is hooked up. There is a connector that has 3 wires in it, high speed relay power, a blue wire, and the ground.
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Casey Meyers
Mar 2, 2016 10:46 AM
Bert87
Aug 23, 2015 03:50 PM
