Fuse box Question. (pic)
Old Aug 11, 2011 | 10:43 PM
tlamm's Avatar
Car: 91 Firebird
Engine: 5.0 TPI
Transmission: 5-Speed
Im trying to figure out why my Driver headlight does not flip back down. Plus my Pass side randomly will go back up and down.
So i looked for fuses and found this.
What fuse is supost to go in the melted area. Right of the 10 and 5 amp fuses. Where are the fuses for the headlight motors would help plz.
Thanks.
Old Aug 12, 2011 | 07:19 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Fuse box Question. (pic)
https://www.thirdgen.org/forums/elec...e-diagram.html
Lucky for you nothing goes there. Looks like the PO tired to pull some serious power from those points and overloaded the circuit. Id pull the block loose and inspect the rear for exposed wires
Headlight motor fuses are in the convenience center on the other side under the drivers side
Be sure your issue is not mechanical before going too deep. Headlight motors need to be rebuilt about every decade. Its also common for the module itself to be giving out
Old Aug 12, 2011 | 11:12 PM
tlamm's Avatar
Car: 91 Firebird
Engine: 5.0 TPI
Yeah i did some searching on here and found the Fuses. Ended up needing a driver side fuse.
Then they worked perfect. Now i have a New Driver headlight motor and awesome flip up headlights.
I will have to look behind the block someday also. I will inspect into it.
Old Aug 15, 2011 | 01:25 AM
horvathjon's Avatar
i have an 1989 firebird and the headlights go up but wont go down when the switch is flipped off. all though when flipped back on it tries to raise them up higher.. help?
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
snowflake
Oct 19, 2015 10:24 PM
Street Lethal
Aug 13, 2015 08:28 PM
