HelP please
Old Aug 14, 2011 | 11:50 AM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
HelP please
Hello i have an 88 rs 5.0 ybi, i bought a distributor for the car but i can only find 1 of the 2 connectOrs that go pluged into the ignition module, i bought the car without an distributor, also if its an ignition module why does the rotor have a center connector? Herea some pictures
Old Aug 14, 2011 | 01:42 PM
pvr007's Avatar
Engine: 305 TBI
Re: HelP please
BumP.
Old Aug 14, 2011 | 07:49 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: HelP please
Do you have the plug that goes in the bigger socket? The wire from the coil goes in the little one. The coil output goes to the center terminal. Are you missing the coil?
Old Aug 14, 2011 | 08:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: HelP please
Yep - that's an external coil distributor. You need a coil.
Old Aug 14, 2011 | 11:09 PM
pvr007's Avatar
Engine: 305 TBI
Re: HelP please
WAt i need a what??? External coil? Then the center wire goes to th outer coil?
Old Aug 14, 2011 | 11:14 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: HelP please
yeah you got a external coil distributor. So either get a coil or get one with an internal coil. DUI has them new or you can go to the bone yards.
Old Aug 15, 2011 | 12:30 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: HelP please
Yes. External coil. Just like the older dizzies.
People have attached the name of 'HEI' to the dizzies with the coil on top, whereas in reality, even the slightly older dizzies were a HEI. 2 different HEIs. External & Internal coils.
Nothing wrong with the external coil. Use it & go.
Old Aug 15, 2011 | 02:36 AM
pvr007's Avatar
Engine: 305 TBI
Re: HelP please
But my car, i can only find 1 cinnector...... So what should i do?
Old Aug 15, 2011 | 09:18 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: HelP please
Which connector do you have? Do you have a Haynes or Chiltons manual or any kind of book with diagrams? I'll see if I can get some pics to show how the setup should be
Old Aug 15, 2011 | 01:40 PM
pvr007's Avatar
Engine: 305 TBI
Re: HelP please
I can only find the 4 pin connector
Old Aug 15, 2011 | 04:02 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: HelP please
That's the only distributor connector that comes on the engine harness, the other one comes from the coil. I took some pics that may help explain. Could you send me your email address again for pics, I haven't found it yet. Never mind, I found it
