Hatch motor adjustment
Old Aug 19, 2011 | 08:50 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
The hatch motor does not " click " when closed.
Battery dies over night.
When I charge the battery, the hatch motor " sounds " like it still wants to pull down more.
Is there a way to adjust the travel so it does not want to keep pulling down??
Thank You for any tips!!!
( edit )
Found a tip to try
Old Aug 20, 2011 | 04:25 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Hatch motor adjustment
Mark the location of the pull-down unit to the body using a permanent marker or scratch awl. Then loosen the three 13mm screws that hold it to the body, slide the pull-down frame up a bit, then tighten the 13mm screws. Markign the location before you move the pull-down unit helps you keep track of how much you've moved it.
Lon
Frozer!!!
Jan 19, 2024 04:55 PM
zayne0
Aug 24, 2015 07:22 PM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
stalkier
Aug 13, 2015 12:59 PM
