91 Camaro Wiring
Old Aug 25, 2011 | 05:57 PM
'91RS's Avatar
Car: 1991 Camaro RS
Engine: 305 V8
Transmission: Automatic
Axle/Gears: Stock
91 Camaro Wiring
My headlights work on highbeam all four lights are lit. When i go to low beam no lights are lit. If the drivers side is out will that cut current to the passenger side? I could only reach in to the passenger side to check with the meter and it reads no current. I'm not sure about the driver side. Like I said if the driver is blown would it stop the passenger from working. Also are the low beam bulbs dual filament? Are all four supposed to be lit when the high beams are on?
Old Aug 25, 2011 | 07:35 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: 91 Camaro Wiring
I'm pretty sure they are not in the same cicuit so if one goes out the other should stay lit. The bulbs aren't dual filament, 2 for lowbeam and 2 for highbeam. All four will be on when the highbeams come on. I would say check the wiring or maybe even the headlight switch itself. Do your parking lights come on when you pull the headlight switch?
Old Aug 25, 2011 | 07:59 PM
'91RS's Avatar
Car: 1991 Camaro RS
Engine: 305 V8
Axle/Gears: Stock
So basically the low beams just stay on when the high are on they don't get brighter like 4 high beam bulbs. everything works as it should just not the low beams. If they are all 4 on when my high beams are on then the low beams wouldn't be burnt out correct?
Old Aug 25, 2011 | 08:02 PM
'91RS's Avatar
Car: 1991 Camaro RS
Engine: 305 V8
Axle/Gears: Stock
I also wouldnt think it would be the headlight switch because the lights work not the low beams though. is it possible the high low switch on the column by the pedals is bad?
Old Aug 25, 2011 | 08:40 PM
Yea they just stay on when your highs come on. Bulbs arent burt if they come on with the highs. Look into the high/low switch like you said. Other than that switch and the headlight/parking lamp switch I cant think of anything else.
Old Aug 25, 2011 | 09:25 PM
'91RS's Avatar
Car: 1991 Camaro RS
Engine: 305 V8
Axle/Gears: Stock
I'm going to do that. I'm starting with the cheaper of the two options the hi lo switch is only 12.95 the headlight is upwards of 40
Old Sep 16, 2011 | 07:33 AM
Bighawk's Avatar
Car: 91 Camaro Z28
Engine: 5.7L
did the hi lo switch work? im having the same problem except for me its the high beams that wont cut on. every now and then they come on when i try to go to brights so i no its not the lights themselves.
rocn7roc
Sep 21, 2021 02:16 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
