Radio won't work after distributor change
Old Sep 6, 2011 | 02:04 PM
zapr's Avatar
Car: 1985 camaro z28
Engine: 305 lg4
Can anyone tell me why my radio won't work after a distributor change. Yet if I disconnect the battery and reconnect, it works. But when I shut the car off and restart it, it won't work again..........Thanks
Old Sep 7, 2011 | 08:34 PM
zapr's Avatar
Engine: 305 lg4
Re: Radio won't work after distributor change
Nobody?
Old Sep 7, 2011 | 08:53 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
neither are related wiring wise, the radio must of just taken a crap at the same time.
Old Sep 7, 2011 | 08:54 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
I'm not radio-savy, so bear with me...
That is odd to say the least!! Does it have speaker protection that kills the radio if it's too loud so the speakers don't blow? Maybe a ground or power wire is loose?
Just a stab in the dark, sorry!!
Maybe if you tell the brand, any power amps, speakers, someone with the same set up had the same problem..?..
Good luck
Old Sep 7, 2011 | 10:52 PM
zapr's Avatar
Engine: 305 lg4
Stock sound system. I realize the distributor has nothing to do with the radio but I can't figure out why it will work after disconnecting the batterry and reconnecting it until I shut the car off, then when I restart, it won't work. I dunno.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
