trunk latch solenoid stopped working
Old Sep 6, 2011 | 05:21 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
so my trunk has that auto pull down thing.
To start, my trunk was down and in the locked position when my battery died and drained to 0 so my car had no power. I happened to put the key in the back and popped the trunk and it opened. Now the solenoid is in the down position because it didnt pop up with no power. Now i cant get the trunk to close at all because the solenoid thing wont come up. Battery is now fully charged
Any advice on how to reset this system would be appreciated
Old Sep 6, 2011 | 11:58 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: trunk latch solenoid stopped working
This is a power pull-down motor problem, not a hatch release solenoid problem. They are powered on two completely different circuits. First remove the hatch surround trim panel and check that you have power at the red/white stripe wire that plugs into the blue wire.
Lon
Old Sep 26, 2011 | 12:07 PM
richy2001's Avatar
Car: 86 TTOP Black Trans AM
Engine: Base 5 Liter
Transmission: 5 Speed Manual
Axle/Gears: My Car has some
Lon
Hi
So what does one do after finding that the red and blue wire has power. When I re-connect the white connector, the relay clicks but I cannot get the hatch lock to close the hatch.
Can you explain, please.
Old Sep 26, 2011 | 10:43 PM
lonsal's Avatar
Yes I can. Call me.
Lon
Old Sep 29, 2011 | 02:02 PM
richy2001's Avatar
Hi
Another member showed a picture of the small lever on the actual hatch lock that is the switch that trips the motor. I pushed it and all is well now. I will now give the lock slides some WD40 as you recommend. You 3gen guys are awesome!
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Poncho92
Aug 7, 2015 08:15 PM
