Wipers will not work!!!
Old Sep 6, 2011 | 09:32 PM
brutforceZ28's Avatar
Car: M1A2SEP Tank, project car 83 z28
Engine: 5.0
Transmission: 5 speed
Axle/Gears: what ever came in the car
i changed out my steering clumn in my 83 z28 to a 82 tilt column. Everything plugged in and car started but wipers will not come on fuse is good, prior to the swap they worked fine. I also put the old lever off my column on since the 82 tilt column had cuzse and the end of the lever was broke. I even tried with both levers no wipers I have limited knowledge about camaros only what i read or someone tells me. Is there a way to check the lever to see if its sends out juice or do i have to check the wiper motor. I'll hook up a toggle switch for the time being just to get it inspected and mess with the lever and wireing later but I dont even know what color the wores are for the motor. HELP PLEASE oh and my 4 ways (hazards) wont work either but can't remember if they did before the swap blinkers work fine
Old Sep 26, 2011 | 12:53 AM
Transam173's Avatar
Re: Wipers will not work!!!
Did you find out what happened. I just changed my steering column from regular to a tilt. Everything works but my wipers. The wipers worked before I switched the columns. If you fixed yours, let me know what to do to fix mine.
Old Sep 26, 2011 | 11:59 PM
Engine: 5.0
If you still have the old column. you can change out the parts that the wiring harness plugs into but what i had to do was. on the wiper motor as you are looking at it. the plug has umm 3 wires take it off and flip it over. mine work like this but only on high for the time. you can also buy a new motor but has to be delay motor for it to work. hope that helps
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
colton_carlson
Mar 8, 2019 12:21 PM
Fronzizzle
Aug 17, 2015 02:52 PM
slade5612
Aug 11, 2015 07:19 PM
