Is this the right tachometer wire? Picture
Old Sep 10, 2011 | 03:46 PM
Jerome Casi's Avatar
Car: 1989 Camaro RS
Engine: 355
Transmission: 5 speed Manual
Axle/Gears: Stock
After getting a new cluster and getting my gauges to work, the Tach is still pegged and doesnt move.
I am wondering if it could be because this car was converted to a carb setup? you can see where its plugged into the distributor where it says "tach" but im not sure if its plugged into the correct wire in the loom.
If it is, what would be my next best trouble shooting step?
Thanks in advance
Attached Thumbnails Is this the right tachometer wire?  Picture-imag0652.jpg   Is this the right tachometer wire?  Picture-imag0653.jpg
Old Sep 11, 2011 | 12:10 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Is this the right tachometer wire? Picture
The stock tacho wire runs direct from dist to cluster so nothing should have changed with the conversion unless you cut the wire
Check continuity of the wire from tacho to cluster
Old Sep 11, 2011 | 09:31 AM
Pocket's Avatar
Car: 91 Trans Am
Next test for 12v at the cluster and then test for a good ground
Old Sep 11, 2011 | 08:10 PM
Car: 1989 Camaro RS
Engine: 355
Axle/Gears: Stock
Unfortunetly I did not do the conversion, I was hoping that the connector I am holding in the picture might have been a dead giveaway as to whether that is right or not, as it looks like the connector is stock.
I tried checking at the cluster for continuity, but had spotty results so I will try it again. I will also try the 12v light method and see what I get.
I appreciate the help!
Glowsock
Jul 24, 2025 03:15 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
ChevyZ71
Aug 13, 2015 07:30 AM
