Please help me out.
Old Sep 15, 2011 | 02:37 PM
xxZ28xx's Avatar
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
Please help me out.
Go to my other post and check out these wires. I would really appreciate if you could tell me what these are and what they go to so I can go buy new ones as soon as possible. Its another post but no answers and Im trying to get a quick response so I can buy these wires thank you.
https://www.thirdgen.org/forums/tran...ttom-pics.html
Old Sep 17, 2011 | 11:40 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Please help me out.
I looked at the pics and read the posts. Since those wires are down by the trans, they are going to be for the lock up torque converter connector. I think its a 4 wire connector. The lock up converter when working will drop the rpm some more when driving for better gas mileage. Converter lock up is controlled by the ecm. The third pic is an electric speed sensor for the speedo. In 88, the speedo will be cable driven. Does the speedo work? I think someone put in a newer or wrong trans in your car. If you look in that area of the trans, you should see the end of the cable for the speedo thats not hooked up.
Bubbajones_ya
Jul 6, 2024 08:32 PM
RedLeader289
May 28, 2019 01:47 PM
mattcanty
Oct 12, 2015 11:08 AM
mfp189
Sep 27, 2015 09:25 AM
earlpote
Sep 12, 2015 11:55 AM
