Help: A/C Comp.not engaging,blower & wipers
Old Sep 27, 2011 | 06:07 PM
ikeepitreelz's Avatar
Car: 1988 gta-
Engine: 383 tpi
Transmission: 700 r-4
Hello all:
I have a problem where my a/c compressor stopped engaging,blower motor won't work and the wipers, thinking it was a fusible link, I checked them all and they are good, so i check power to wipers,blower motor and a/c clutch and they had power, so thinking it's a ground i tested the ground from the engine to the firewall and it seemed good, i decided to ground the casing to the wipers and voila, everything mentioned above that wasn't working ,started working, same thing happens if i ground the blower motor housing, where can the ground be to these items, all other electrical items work fine
. thank you guys!
Old Oct 11, 2011 | 04:02 PM
soileaujp's Avatar
Car: 88 IROC Z28
Engine: L98 350
Axle/Gears: 3:27 posi
Re: Help: A/C Comp.not engaging,blower & wipers
The same thing just happened to me and i cant figure it out. Have you had any luck fixing it. If so please let me know how you did it. Thanks
Old Oct 11, 2011 | 04:16 PM
Car: 1988 gta-
Engine: 383 tpi
No luck i injured my back at work so i haven't been able to figure it out. The last attempt i discovered that if i ground the casing to the wiper motor (metal part of course) they start working along with the a/c compressor, temporarily i have a wire grounding the motor. I am guessing its gotta be a common ground shared by both. let me know if YOU find out anything or if grounding the wiper motor to the battery works for you.
Old Oct 11, 2011 | 04:18 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Back of right cylinder head I believe is one I'd check first. Another major ground is under steering column just to the left. You'll have to remove lower dash cover to get to that one.
Old Oct 12, 2011 | 01:46 PM
soileaujp's Avatar
Car: 88 IROC Z28
Engine: L98 350
I have located the problem for my issue with the AC blower and the wipers. There was a single prone black connecter on the passenger side of the firewall on the outside front of the blower motor that was loose. I will post a pic of it. My AC starting blowing again as did my wipers work as normal again.
Old Oct 12, 2011 | 02:07 PM
Car: 1988 gta-
Engine: 383 tpi
Is it the one next to the blower housing?
Old Oct 12, 2011 | 02:19 PM
soileaujp's Avatar
Car: 88 IROC Z28
Engine: L98 350
Here is the pic of the wire that was loose. Hope this helps with your situation.
Attached Thumbnails Help: A/C Comp.not engaging,blower & wipers-wire.jpg
Old Oct 12, 2011 | 02:27 PM
Car: 1988 gta-
Engine: 383 tpi
Hmmm i'll try that, although i could of sworn i checked that, unless its broken somewhere below the insulation, so your telling me that was loose and once you moved it wipers AND a/c started working again?
Old Oct 12, 2011 | 02:37 PM
soileaujp's Avatar
Car: 88 IROC Z28
Engine: L98 350
Yes. I moved that around while car was running with AC on and the wipers turned on.
After moving it around they turned on. I moved it again and they shut back off. I dont know why or what that wire does but it obviously controls those items somehow. So i ensured a good solid connection and wipers and ac work as advertised.
Old Oct 12, 2011 | 02:46 PM
Car: 1988 gta-
Engine: 383 tpi
Tip, get some electric grease and dab some on the connector and terminal. I'll check this later this week, thanks for the help.
jrdturbo
Mar 31, 2016 02:58 PM
codeysabatini
Nov 10, 2015 04:07 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Hal87
Sep 26, 2015 09:26 PM
