My tailight issue
Old Sep 27, 2011 | 11:24 PM
lethaldomestics's Avatar
My tailight issue
Ok So when i go to use my left or right turn signal my inner embers both flash as if the emergency lights are on. When i have my head lights are on only the running lights work no turn signals.
I have changed out the flasher sever times. non of them make this problems go away. Any ideas?
thanks TG.
Old Sep 28, 2011 | 12:38 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: My tailight issue
BUMP
Old Sep 28, 2011 | 03:09 PM
bump
Old Sep 29, 2011 | 03:29 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
which flasher did you change? theres 2 of them, one for emergency flashers, and one for the turn signals.
Old Oct 3, 2011 | 11:48 PM
i did not know that. where is the other located?
Old Oct 3, 2011 | 11:51 PM
HeavyThundar's Avatar
Car: 81' Z28, 87' Iroc Z28, 05' GMC Z71
Engine: LB9 - 305 TPI - 190 H.P.
Axle/Gears: G92 - 3.23
Multi-function switch?
Old Oct 3, 2011 | 11:54 PM
I did not know there was more than one. Where is it located.
Old Oct 4, 2011 | 12:28 AM
travis401's Avatar
Car: 91 Camaro RS
under the dash somewhere. on my 91, theres one buy the fuse box, and another on the other side, by the courtesy center (black box that holds the door chime/seatbelt warning bell)
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
90formulaVortec
Sep 7, 2015 06:54 PM
