dead battery after two days
Old Sep 28, 2011 | 12:58 PM
lowbird's Avatar
Car: 88 firebird
Engine: 350tpi
Axle/Gears: 373
anyone else had a battery drain from the ctsy fuse line? I have messed with this for a week now and still cant find my draw. If i pull the 20 amp fuse it goes away but is seem that feeds so much like door locks,dome lamps,radio,lighter but all the diagrams only show the door locks. This is killing me .lol
Old Sep 28, 2011 | 08:05 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: dead battery after two days
Do you mean the ACC fuse, can't find one on my diagrams called the ctsy. Now you've narrowed it down to the fuse, unplug the devices powered by it one by one, until the drain goes away. If it doesn't, that leaves the loom itself.
Old Sep 28, 2011 | 08:29 PM
mrrman's Avatar
I have the same issue on my 87 TA. TreeFiddy, what do you mean by that the problem is in the loom? Can you clarify this.
Old Sep 28, 2011 | 10:15 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Meaning that if you have a circuit with all the powered devices that are on it disconnected, and you are STILL getting a power drain, there must be a problem with the wiring itself.
It's unlikely in this case, usually a wiring problem will be either a fully or intermittently open circuit, which will just cause the circuit not to work, or a dead short to ground or other wiring, which will cause the fuse to blow.
However, on various cars over the years - I have come across a situation where insulation between two wires had deteriorated and somehow allowed a low resistance between them, but not quite a short. Similarly with a wire going thru a firewall, not correctly bushed. Also think I had a connector on something once that filled up with years of goop around the terminals, which conducted a bit. That kind of stuff - not fun to track down.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
Ranbo108
Sep 9, 2015 12:20 PM
andy74
Sep 3, 2015 08:41 AM
