Car died!!!! Please HELP!!!!!!!!!
Old Oct 9, 2011 | 05:09 PM
jftbus's Avatar
I tried to turn on my rear defrost while the car was running and heard a few clicking noises and then my car just died. I have an 84 camaro Z-28. I have interior light no dash lights, have headlights! When I try to start the car nothing at all. Does anybody have any hints that might help? Thanks!!!!!!!
Old Oct 9, 2011 | 05:24 PM
HeavyThundar's Avatar
Car: 81' Z28, 87' Iroc Z28, 05' GMC Z71
Engine: LB9 - 305 TPI - 190 H.P.
Axle/Gears: G92 - 3.23
Re: Car died!!!! Please HELP!!!!!!!!!
Grab a test light, and begin checking fuses.
Old Oct 10, 2011 | 08:01 AM
jftbus's Avatar
have checked all fuses and they are good!
Old Dec 3, 2011 | 08:11 PM
89firechicken89's Avatar
Car: 91 camaro rs
Engine: 5.0
im having the same problem but mine just didnt start one day it looks like there isnt enough power in all of my gages and all it does is flicker and make clicking noises when i turn the key to start it this is the second time and it hasnt started since then
Old Dec 3, 2011 | 08:19 PM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
don't just tell us you "visually looked" at them. Get a test light, meter, and test it.
Old Dec 4, 2011 | 11:11 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
usually dimming lights and clicking noises from the starter indicate a dead or weak battery, or loose or corroded connections, or a possbile ground issue.
Old Dec 4, 2011 | 01:56 PM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
If fuses check out good. Clean all the battery/starter connections good and make sure the battery is good. Goodluck ;P
Old Dec 4, 2011 | 02:02 PM
travis401's Avatar
Car: 91 Camaro RS
since you heard some clicking noises when you turned on the defroster, im guessing something got grounded out and poped some fuses or possbily a fusable link.
Old Dec 4, 2011 | 07:13 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Sounds like you popped one of the fusible links at the starter. Two links feed power to the cabin, one generally for the lights and the other for everything else including the demister.
Since you still have lights, sounds like you popped the second one. Obviously some kind of short with the demister, most likely with the lh hatch strut at a guess.
Old Dec 4, 2011 | 07:20 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
My car wasn't starting the other day and it was a disconected wire. However my fuel pump was priming and my dash lights came on. Sound like you have a short in your rear defroster wire, and you blew a fuze. Good luck man!
Old Dec 5, 2011 | 12:59 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Linked is the circuit diagram for my 86, don't know what year OP's is but it's probably the same. There is no fuse for the demister power, just the pwr acc circuit breaker and the fusible link.
The gauges/accessory fuse could be gone, but I don't imagine it would cause a no-start.
http://92b4crs.tripod.com/86wiring/dia-pics/61-0.jpg
Old Dec 5, 2011 | 09:48 AM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Crazy, the exact same thing happened to me today...Have headlights and dome light, no electrical current to the dash back.... I Love this site, Always get my answers quick.
Do you have to solder the fusible links in?
Old Dec 13, 2011 | 11:24 AM
Car: '87 Iroc-Z
Did you ever figure it out bro what was wrong?
Old Dec 21, 2011 | 06:42 PM
jftbus's Avatar
Thanks for all your help everyone!! I had put it away for the winter but will be replacing the motor in a few months, so i will get to check everything ouy then! Like i said thanks for all the hints and ideas!!!!!!!!!!!!!
Old Dec 21, 2011 | 07:12 PM
Car: '87 Iroc-Z
Well you guys dont forget bout me... I'm having the same problems with my car
Old Jan 8, 2012 | 02:17 PM
wayner's Avatar
Car: 1980 camaro, 1985 k20, 1988 TA GTA,
Engine: GTA 350 TPI, K20 and camar-carb 350
Transmission: GTA-swaped 5 speed,auto k20 &camaro
Axle/Gears: 9 bolt GTA disc rear
anyone find a fix for this same thing here was driving all fine even used the defrost on the way to where i was going but on the way back driving everything was fine hit the defrost and motor killed out no pop start, no crank, no dash lights (digital dash) got it home and checked for power at the fuse box everthing is dead for power but headlights fuse has power nothing then i turn the key no crank no pump prime no nothing.......
Old Jan 8, 2012 | 05:24 PM
travis401's Avatar
Car: 91 Camaro RS
check the fusable links on the starter. thats step #1 when you loose power to the cabin.
on a side note, break your posts up into coherent sentences. it makes it easier for us to read, and to better understand and help you.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
