stupid turn signal problems need help asap
Old Oct 18, 2011 | 01:34 PM
VelocitySc0pez's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 TBI
Hey guys. Im on my second ticket and under court supervision for driving. AND MY TURN SIGNALS WONT FREAKIN WORK!!!
a month or two after I bought my camaro they started being wacky.. flashing randomly and not in sequence like they should. then sometimes the turn signal would just stick. and now it just wont work. Ive already gotten a ticket for not using them BECAUSE THEY WONT WORK.
HAZARD LIGHTS DO WORK THOUGH.
I know its either something to do with the fuse, or the turn signal relay.
I need help, what should I do? my dad threw away my owners manual so i have no clue which fuse is which, or where the turn signal relay is located. id appreciate all help thanks.
Old Oct 19, 2011 | 08:00 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Re: stupid turn signal problems need help asap
turn signal relay is located right under your steering column, probably in a bracket. It's a tingy aluminum type thing. It should have two prongs out the bottom. Most parts stores have them.
Old Oct 20, 2011 | 08:08 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
yea, id check the turn signal flasher.
Old Oct 20, 2011 | 08:21 PM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
also make sure none of your turn signal bulbs are burnt out, my blinkers would stick when I had a bad bulb
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
