Cleaning up the factory wiring harness for a carbed car
Old Oct 31, 2011 | 03:43 PM
iceman383ja's Avatar
Car: 91 Z28, 2014 ZL1
Engine: 383, LSA
Transmission: WC T-5, T6060
Axle/Gears: 3.73 in both
Hey guys I'm looking for a little help on this one. I want to completely remove all components of the TPI setup that I had to clean up the bay and correct some wiring issues with the car. From what I can tell the ECU sends the speedometer the signal from the trans and still controls the VATS. The car is a 91 Z28 with the 5.7 auto setup, recently converted to a T5. Can anyone shed some light on some type of work around for the speedo and VATS?
Old Oct 31, 2011 | 07:01 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Cleaning up the factory wiring harness for a carbed car
if you remove all the tpi stuff, are you converting to a carb? if so, the computer can go. youll need to bypass the start enable relay for the car to start. the speedo will still function fine without the computer iirc. it may need a little reworking on the wiring but im not 100% on that.
do a search on carb conversions, all those questions and more will be answered.
if youre not ditching the tpi, then I have no idea what youre trying to accomplish.
Old Oct 31, 2011 | 07:14 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/carbswap
the vats programming is in the ecm's memcal, no worries on that.
Old Oct 31, 2011 | 09:21 PM
Engine: 383, LSA
TPI has been gone for some time now. Just cleaning up the engine bay.
What do I need to do for the bypass on the start enable relay?
Old Oct 31, 2011 | 10:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tpi/...ay-bypass.html
Jorlain
Aug 24, 2022 05:11 PM
specialized
Jun 18, 2022 09:26 AM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
mx127
Aug 10, 2015 08:13 AM
