Identify what does this relay control
Old Nov 1, 2011 | 01:58 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
its located in the drivers side back corner of the engine compartment near the brake booster. I unplugged it and noticed nothing different so i think its not used my my engine setup anymore. What was it for?
the wires coming out of it are yellow, red, green, and brown
Old Nov 1, 2011 | 02:33 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Identify what does this relay control
possible fan relay
Old Nov 1, 2011 | 02:36 PM
travis401's Avatar
Car: 91 Camaro RS
it looks like theres a black wire with red stripe in the second pic, if it is then its the fan relay
Old Nov 1, 2011 | 11:19 PM
ChevyRS-305's Avatar
Just found out what this was a week ago when i was diagnosing a crank no start problem... had the whole harness pulled and laying across my passenger side fender. Come to find out that relay contains your injectors(green), fuel pump(brown), and fan(red) the other wire is a positive that kicks your fan on. If you put the fan and positive wire together your fans should pop on. An intresting fact i also found... did you know your injectors provide a positive lead for your fuel pump? Yep its spliced right into it... food for thought
Old Nov 2, 2011 | 08:01 AM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
thanks, my fuel pump , fan are on a new circuit
and my car has been switched to carb.
im going to remove it
Bubbajones_ya
Jul 6, 2024 08:32 PM
Linson
Sep 21, 2015 01:08 PM
sahlomonic
Sep 20, 2015 07:15 PM
Gunsbee
Sep 7, 2015 07:10 PM
