91 Z28 Hatch Pull Down Wiring
Old Nov 5, 2011 | 04:24 PM
reefland's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L
I've done a lot of searching and none of the results match the wiring color I have so I am posting to see if someone can help. First, I have tested the motor and it works fine with I wire direct with 12v and ground it.
Attached are two images, 1 of the harness attached to the motor and the other is the mess of wires that come from behind the rear panel. Obviously the wiring is a mess and I can't figure out what goes to what.
The release latch in the console does not release the hatch and the motor does not go up and down unless I hard wire it with the wire labeled as 12v and ground it.
The first image is from the car and I tried to label the wires that I can identify. Odd that one of the black ones has 12v. The second image is of the harness.
Any help would be appreciated!
Attached Thumbnails 91 Z28 Hatch Pull Down Wiring-hatch_from_car_post.jpg   91 Z28 Hatch Pull Down Wiring-hatch_from_motor.jpg
Old Nov 5, 2011 | 05:04 PM
Drew's Avatar
Re: 91 Z28 Hatch Pull Down Wiring
That's because you've got the 91.5-92 setup instead of the 86-91.5 trunk pull down.
I can't help you, I don't have a 92 manual, and the 91 manual only shows the early style. Good luck.
Old Nov 5, 2011 | 05:47 PM
reefland's Avatar
Engine: 5.7L
Well that does help some, still looking for some how-to's. I found a schematic but I'm not too good with those...
Old Nov 6, 2011 | 07:10 PM
HeavyThundar's Avatar
Car: 81' Z28, 87' Iroc Z28, 05' GMC Z71
Engine: LB9 - 305 TPI - 190 H.P.
Axle/Gears: G92 - 3.23
I believe the schematic in PDF format, located in post #10 of this thread matches your car.
https://www.thirdgen.org/forums/inte...own-motor.html
Hope it helps. Post your results!
Old Nov 7, 2011 | 05:20 PM
reefland's Avatar
Engine: 5.7L
When I hook the red-white together and ground the black wires from the hatch motor harness, the motor goes all the way down. If I shut the hatch and then open it with the key, it just pops open, no lift up. The only way I can get the hatch motor to go up is the remove the relay attached to the unit and wire the motor directly.
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
z28addict8490
Aug 7, 2015 08:48 PM
