switches
Old Nov 11, 2011 | 06:55 PM
19f0rmula88's Avatar
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Axle/Gears: 10 bolt 3.73
switches
im installing an engine in my firebird and it doesnt have any wiring at all. i want to install toggle switches for everything. so i was wondering what gauge wire i will need and what amp the fuse will have to be and the size of the switch. and will i need to run a wire from battery to the distributor? its also a computer controlled carbureted engine will i be able to use this distributor or will i have to swap in a vacuum advance one?
Old Nov 12, 2011 | 12:38 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: switches
If you plan on having the engine fire up.
If you don't understand the basics of automotive wiring ( as evidenced by your question above )
then you may be out of your depth on this project
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
