HEAT/AC BLOWER WONT BLOW HIGH
Old Nov 26, 2011 | 10:31 PM
Lively13's Avatar
Car: 1982 Camaro Z28
So heres the thing, all of a sudden my blower wont go to high, what i mean by that is, when i switch it to low and medium everything is normal but when i switch it to high its as if i switched it to off. No air comes out on high.
A few days before this problem i got rid of unused wiring under the hood. The last owner switched it from fuel injected (crossfire) to a carburetor. so i removed this wires that werent connected to anything (a few wires must have hit the engine cause they were melted.) I also took off the High speed relay, but put it right back. So thats what i did.
Yesterday however the heater did work when on high. What could have happened?
Old Nov 27, 2011 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: HEAT/AC BLOWER WONT BLOW HIGH
Originally Posted by Lively13
So heres the thing, all of a sudden my blower wont go to high...
The relay controls the high speed, so I assume your issue was with that part. Perhaps lack of contact.
JamesC
Old Nov 29, 2011 | 03:11 AM
Lively13's Avatar
Got it, it was my fault after all, The connection (red wire) that connects at the firwall under the center on the hood area was loose and wasnt getting a full connection. once i unplugged and replugged it back in. It worked perfect. Now im going to replace the blower to see if it will blow harder. Cause mine doesnt seem to blow very hard and takes along time to defog the windows. THANKS!
b4ccamaro
Jun 5, 2016 01:48 PM
327IROC85
Sep 23, 2015 12:11 AM
corey8084
Sep 17, 2015 02:56 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 3, 2015 09:26 AM
