I dont know if this is the right thread
Old Nov 28, 2011 | 04:41 PM
trevorsmith82's Avatar
Car: 82 Firebird/ 79 Camaro Berlinetta
Engine: 151 Pontiac Iron Duke TBI/ 305 SBC
Transmission: THM200/ THM200r4
Axle/Gears: 2.93/ 2.41
I need help finding a hole along the fire wall i put my coil and tubing for my gauge pod(water temp and oil pressure).
Ive been taking my dash apart but cant seem to find anything cant find a hole on the engine bay side
should i drill?
Thanks for any help
Old Nov 29, 2011 | 09:52 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: I dont know if this is the right thread
Sure dude, you have our permission. Just use a proper grommet or gland, so the firewall doesn't abraid the wires/tubing or let fumes/water in.
Old Nov 29, 2011 | 10:36 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
You have a pin on hood mebbe? If so, you could use the hood cable hole.
Old Nov 30, 2011 | 11:45 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
doubt someone with a 2.5l I4 has a pin on hood. just drill a hole and use a gromit to keep from cutting into the new tubes. why are you bothering with mechanical water and oil guages when electric ones are cheap and so much easier to install.
Old Nov 30, 2011 | 11:52 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Agreed. Not to mention what happens if that thin plastic line on the oil pressure gauge happens to break and sprays hot oil all in the car.
Old Nov 30, 2011 | 12:12 PM
travis401's Avatar
Car: 91 Camaro RS
exactly that, you get 200* pressurized oil all over the inside of your car. theres a reason car companies stopped using mechanical gauges a LONG time ago.
Pac J
May 17, 2020 10:44 AM
Elephantismo
Feb 13, 2019 12:51 AM
355tpipickup
Sep 28, 2015 05:50 PM
Linson
Sep 21, 2015 01:08 PM
