turn signal troubles
Car: 1985 chevy camaro,z28
Engine: crate 350,headers,3in exhaust
Axle/Gears: 308------3.73 auburn unit
Hi,i just recieved a camaro for my sixteenth birthday i am new to this site and was refered by my dads friend.I have a small problem though,My turn signal light in the front passenger corner will not turn on,and the turn signal light dash idicator will also not work.But when i put the harzard switch on the lights in the dash, and the turn signal all work.
The only time the turn signal on the passenger side works is if i slightly pull out on the hazard switch,any suggestions? i would also appreciate a wiring diagram for a fuse box
Thank you.
Thank you.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I Blink, Therefore I Think
Due to the fact the right turn signal functions when you pull at the hazard switch, that leads me to believe the switch assembly is worn and should be replaced.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Happy Racing!
