turn signal headache!
Old Dec 18, 2011 | 08:04 AM
1985chevydude's Avatar
Car: 1985 chevy camaro,z28
Engine: crate 350,headers,3in exhaust
Axle/Gears: 308------3.73 auburn unit
Hi,i just recieved a camaro for my sixteenth birthday i am new to this site and was refered by my dads friend.I have a small problem though,My turn signal light in the front passenger corner will not turn on,and the turn signal light dash idicator will also not work.But when i put the harzard switch on the lights in the dash, and the turn signal all work.
The only time the turn signal on the passenger side works is if i slightly pull out on the hazard switch,any suggestions? i would also appreciate a wiring diagram for a fuse box
Thank you.
Old Dec 20, 2011 | 12:18 AM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Re: turn signal headache!
have you tried looking at the flashers? there are two flashers in the car.
when u put the turn signal does it just stay on?
im not sure where they are on a camaro but i know on my firebird theres one under the steering column in the 2nd fuse block. its bolted down. and my 2nd flasher is behind the radio clipped down to the plastic or in that area.
im almost positive it will be the flasher. hope this helps - Aaron
Old Dec 20, 2011 | 05:27 AM
DUDE! thank you i really appreciate it.
Old Dec 20, 2011 | 05:45 AM
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
You may want to stop over at an AutoZone, Advance Auto, or something like that and pick up a Haynes Manual for your car. It has all the wiring diagrams in it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
