Intellitronix gauges help!!!
Old Dec 27, 2011 | 06:17 AM
DanDingo32's Avatar
Car: 1988 Camaro
Got the gauges for xmas for my 88 camaro. NO manual for the install. Ive looked high and low, not just on here but the web. No luck! thank you!!!!!
Old Dec 27, 2011 | 08:55 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Engaged & Enraged
You should have received the instructions in the packaging if new.
Anyway you can call them at 440-668-3399 and request a manual.
On your 88 you’ll need a speedometer adaptor if not supplied.
Generally their color code is
black for ground, red for power, purple for lighting,
White for signal.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Dec 27, 2011 | 08:58 AM
85irocinjected's Avatar
Car: 1991 RS
Re: Intellitronix gauges help!!!
According to their website it is a direct fit and instructions should of come with it. I would email them and have the send you a pdf or something. But it looks like you just disassemble your current cluster and replace the boards with this new one. Then reassemble and slide the cluster back into place. And you have to replace your speed sensor (vss) with theirs? Email/Call them.
Old Dec 27, 2011 | 09:41 PM
DanDingo32's Avatar
Car: 1988 Camaro
my girlfriend got it for me off ebay. brand new unit, came with speed sensor and water temp sender. ill call them/ email them.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
