Check engine light
Old Dec 29, 2011 | 01:54 PM
flyboyaviator's Avatar
Check engine light
Started my 91 Z-28 and right of the bat, the check engine soon light came on, then the engine began to run on and off, open the hood and began to touch cables, when I check the module located rigth on to of the intake manifold, the engine run well, so I squeezed the connection a few times and the engine will almost stop, any how, went back inside and noticed that the check engine soon ligh was gone, and the engine ran fine after that. what module is that located on the intake maniflod ?(newB here) thanks for any info.
Old Dec 29, 2011 | 03:15 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Check engine light
Tps and the iac I think
Old Dec 29, 2011 | 06:17 PM
thanks evilemokid. I need to buy tps. what is the iac?
Old Dec 29, 2011 | 06:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
iac = idle air control
Old Dec 29, 2011 | 06:48 PM
thanks tunedperformanc
Old Dec 29, 2011 | 08:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
MAP sensor is on top of 90 -92 TPI intake
TPS is on the pass side and IAC is underneath the TB.
Old Feb 12, 2013 | 09:11 PM
Guest
Guest
Posts: n/a
(HOLY thread bump batman) Hey, whats thats sensor on the -bottom left in that pic? Im replacing ALL my sensors.
Old Feb 14, 2013 | 07:56 AM
Guest
Guest
Posts: n/a
Anybody?
Old Feb 14, 2013 | 09:08 AM
Twin_Turbo's Avatar
coolant temp switch for cold start injector
Old Feb 14, 2013 | 02:24 PM
Guest
Guest
Posts: n/a
wah...then whats the other 1?
cold start switch
temp probe
temp probe for cold start.
Is that right?
Old Feb 14, 2013 | 03:13 PM
Twin_Turbo's Avatar
the other one is the coolant temp sender (CTS) for the ECM IT has a weatherpack connector, the one for the cold start injector is the brown one and has a injector type connector with metal wire clip. The top is a hose pipe for the water hose to the TB
Old Feb 14, 2013 | 03:28 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
make sure that your wires going to it are good..take the connector off and even wiggle the wires one by one to see if you find any loose connections.Also wiggle each wire while the motor is running to see if the motor shuts off....I actually made a video last night about how to take the pins out of the connectors and how to check the wiring..check out my youtube channel..search KLOWNY1969 and go to my video labeled how to fix/inspect electrical connectors..also subscribe for future 3rd gen related "how to videos" thanks!
Old Feb 14, 2013 | 03:30 PM
Guest
Guest
Posts: n/a
.............LMAO!!!!
[face palm]
<-totally forgot...
Old Feb 17, 2013 | 08:26 PM
Guest
Guest
Posts: n/a
Hey, witch temp sender is it for a 88 L98 Z?
http://shop.advanceautoparts.com/web...e+sending+unit
-Thanks
Old Feb 17, 2013 | 11:35 PM
Engine: Lb9
Transmission: M20
AIRTEX / WELLS Part # 5S1018
Old Feb 18, 2013 | 10:38 AM
Guest
Guest
Posts: n/a
I meant water temp sender for the ECM.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
