MSD Controller does not provide power to the coil
Old Jan 11, 2012 | 02:36 AM
Jose Zuñiga's Avatar
Hello everyone, I'm new on the electrical parts. I recently Bought a GM Heavy Duty box # 10037378 for my 89 Firebird 5.0 TBI, I have read Several diagrams and I installed the box, But when i try to start my car the box does not Provide power to the coil. I searched a lot online but i found little information. It Will Be a bad installation? Or the box is not Compatible with the TBI? or just the box does not work. Please help. Greetings and thanks to all!
Old Jan 11, 2012 | 02:56 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: MSD Controller does not provide power to the coil
Use with GM heavy-duty electronic distributors P/N 10134355, 1005113334, 10037373, and 25500149. Do not use with production HEI system. It is not compatible with the icm.
Old Jan 11, 2012 | 12:55 PM
Hello tunedperformanc, I think the TBI system uses electronic distributor (I think), so it should be compatible. Thanks for responding. Greetings friend!! And what could be the problem?
Old Jan 11, 2012 | 02:03 PM
Engine: Lb9
Transmission: M20
The install instructions state this will not work with production hei that would include the small cap external coil like you have. if you connected right to the pickup coil it might work but who knows for how long and if it would fry the icm.
Old Jan 17, 2012 | 06:14 PM
hello, sorry, i late a lot to respond. What do you recommend? Thanks you very much! Grettings and blessings!
Old Jan 17, 2012 | 06:22 PM
Engine: Lb9
Transmission: M20
MSD 6AL Box with the MSD-8876, you might want to email msd they might be able to do some sort of exchange.
Old Feb 4, 2012 | 03:28 PM
Sorry, again I lasted to answer. Thank you very much for everything! And yet I could not send the box. How I can see if the box works? Thanks.
Old Feb 4, 2012 | 03:40 PM
Engine: Lb9
Transmission: M20
If you don't have the appropriate magnetic style pickup coil. I would call and ask Msd how too tell if this box was updated so you test it with a points distributor.
http://www.msdignition.com/forum/arc...hp?t-1172.html
Old Feb 5, 2012 | 09:08 PM
Oh thanks dude! I hope your answer. Thanks you for all! greetings and blessings!
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
midias
Aug 15, 2015 05:07 PM
L98GTA87
Aug 5, 2015 11:02 PM
