Map Light Rearview Mirror Wiring
Old Jan 12, 2012 | 08:12 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Scored a rearview mirror with map lights today that cam out of a 92 RS.
I'm looking for how to wire this thing up. My Camaro has a plain old rearview mirror, but I do have an overhead console so I don't think this job will be too difficult.
Coming out of the mirror harness, I see 4 wires. One white, one black, one gray and one orange. Obviously the black wire is a ground, but what do I do with the other 3?
Also one other question, The mirror has the two main map lights, the on/off switch on the left side but on the right side in the spot where the switch is on the left, there is a small lens and what appears to be a tiny third bulb inside. What is the purpose of this third bulb?
Thanks.
Old Jan 12, 2012 | 08:59 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Map Light Rearview Mirror Wiring
Sounds like you got a light sensitivity Automatic dimming rear view mirror...
That's not a 3rd blub its probably the green LED that lights up when the mirror is in the non-glare position... colors are different from my diagram but...
One wires hot all the time ( map lights )
One wire only works when the ignition is turned to key on.
One wire gos to your transmission ( in automatic transmission it is the gear selector switch. In a manual transmission it is the back up switch )
One wire is ground.
Old Jan 12, 2012 | 09:15 PM
Car: 1985 Z28
One wire is ground.
Impossible since I opened the mirror and all it was was 3 bulbs, wiring and glass. No circuitry whatsoever.
I continued to use the search function using different terms and finally found out what it is. Are you aware of the "Mystery dash light"? You know, the one that shines down on the HVAC controls?
Well, turns out this is It's brother light. It's a tiny lightbulb inside the mirror that is supposed to stay on at all times and shine down on the HVAC controls. I have read however, that like It's underdash counterpart, it is so dim you are unlikely to ever notice it LOL!
https://www.thirdgen.org/forums/elec...or-wiring.html
Just opened the mirror again for a closer look. Look like we have a T74 bulb in there:
http://www.bulbtown.com/74_MINIATURE..._BASE_p/74.htm
Old Jan 12, 2012 | 09:41 PM
FueledSoul's Avatar
glade you fingered it out... makes since as to why the wiring colors didn't match up
Old Jan 12, 2012 | 09:46 PM
Car: 1985 Z28
Yeah. You basically just splice the extra wire into a constant 12v source, which is the same wire that the switched input on the mirror goes to. Piece of cake.
Caspar
Jun 19, 2016 11:19 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
Omega
Aug 10, 2015 12:46 PM
