Distributor to Coil and then?...Wiring Question
Car: '09 Pontiac G8 GT - 12.76@109
Engine: 436HP 6.0L
Transmission: 6L80E
Axle/Gears: 2.92
Sorry if this seems like a basic question but I've searched on this forum, Googled for articles & pix, read the '89 Service Manual, etc and I am still confused.
Vehicle: 89 Formula 350. Remote Coil.
I can't figure out where everything goes.
A. From the 2-pin side of the HEI module inside the Distributor, a White Connector with Pink Wire AND a Brown Connector with White Wire come out.
Where do those 2 wires go to?
B. Then the Coil has a Grey Connector with both Pink and White Wires AND a Black Connector with both Pink and White Wires.
Where do those 4 wires go to?
Appreciate the help!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Distributor to Coil and then?...Wiring Question
the pink and white on the coil are the pink is the coil acc power and white is a tac lead. there is a jumper from the coil to the distributor icm and the other for wire from the icm goto the ecm for the high and low signal.
Engine: 436HP 6.0L
Transmission: 6L80E
Axle/Gears: 2.92
Alright, I'm really trying here. Do I have this correct?
The pink & white wires coming from the Black Connector on the coil Go To the distributor.
The pink & white wires coming from the Grey Connector on the coil Go To Ignition and Tach.
Or do I have the Grey and Black reversed?
Thx.
Thx.
Engine: Lb9
Transmission: M20
The grey connector with the white and pink goes on the coil the black connecter inter locks to the get connecter on the coil and attaches to the icm on the distributor
Engine: 436HP 6.0L
Transmission: 6L80E
Axle/Gears: 2.92
One more queston and you'll understand why I was confused.
So the pink and white wires coming out of the grey connector that is attached to the coil go to where? They are cut on mine. Where should they end?
Engine: Lb9
Transmission: M20
Pink is a switched ignition, white is tach if equipped.
92camaroJoe
Aug 13, 2015 06:07 AM
