Wiring for MAT/IAT '730ecm
Old Jan 20, 2012 | 01:31 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
tomorrow i will be diagnosing the IAT circuit and i cant remember if the tan wire at F16 supplies voltage and how much. does anyone have info on this? iirc the black wire to B5 is the ground? i have a wiring diagram from here....
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
thanks!
Old Jan 20, 2012 | 09:18 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Wiring for MAT/IAT '730ecm
so i tested the IAT itself this afternoon and its well within spec. 5V on the tan wire and did a quick continuity test on the ground and that checked out. tomorrow ill be able to get to the ecm for further analysis. what is confusing to me is that in the wiring diagram, it shows the IAT shares the same ground as the TPS. this strikes me as wrong since the ecm would use the TPS circuits leftover voltage first? not sure if it needs to be an isolated circuit. should i have the IAT ground on pin B5 by itself?
thanks!
Old Jan 21, 2012 | 09:09 PM
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
welp, today i looked at the IAT circuit, even ran a new ground to isolate the circuit. works good, but still no readings in the datastream. so its the circuitry in the ecm thats bad or a likely glitch in the bin/adx.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
