Dome Light And Ciggarette Lighter
Old Jan 29, 2012 | 11:39 AM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Ok so i got my car running after 7 years of being outside in the harsh seasons. so now my problem is this. my dome light is not turning on and my cigareete lighter is not working. where would i go to see where the problem is? one time i shut the door and it turned on all of a sudden, now it is now? any ideas please help, i got some accessories that need the lighter compartment.
Old Jan 29, 2012 | 11:53 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Dome Light And Ciggarette Lighter
CTSY fuse.
Old Jan 29, 2012 | 11:59 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
where would this be located? sory for the dumb questions.
Old Jan 29, 2012 | 12:44 PM
BT85's Avatar
Car: 85 Camaro Z28
yea most likely its the fuse. If its like my car the fuse box should be in between the steering wheel and the gas and brake pedal (like under the dash)
Old Jan 29, 2012 | 04:22 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
checked and i didnt see any CTSY fuse in there.
Old Jan 29, 2012 | 04:45 PM
crazy82's Avatar
20amp fuse its like the third one down. if your looking at it upsidedown it would be on your right side. if it keeps blowing unplug the cigerete lighter, just went thru this with my car
Old Jan 29, 2012 | 05:14 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, 20 amp fuse. If you're sitting in the driver seat, it's on the third row back from the one closest to you, second from the right
Old Jan 29, 2012 | 05:30 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
ok i will check that.
Old Jan 30, 2012 | 12:08 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
bump, anyone know? what else or where i can look to see if the rats tore up
Old Jan 31, 2012 | 09:36 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
does anyone else know where i should be looking?. dome light never turns on and cigatrete lighter give off no power.
Old Feb 2, 2012 | 09:28 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
{SOLVED}
Old Feb 2, 2012 | 01:31 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
What was the problem and how did you fix it?
Old Feb 2, 2012 | 05:04 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
well the fuses where good but somehow it was look from the back of the fuse box so i pushed it back and right away i got energy to the dome light and cigarete lighter.
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
